Originally Posted by cheeky Hi Wayne,
This is what I need but I am 51 old and 2 stupid to use this code.
Now what?
Regards, Peter cheeky@acenet.co.za |
Hi Cheeky,
The source code is used to create the EXE file. You don't need to know how the source code works. It is posted for the geeky ones here.
What you do need is the EXE file. It is located at:
http://www.cnczone.com/modules/Downl...file.php?id=22
It is zipped up using winzip.
www.winzip.com
After you unzip the EXE program, it is ready to use.
Start the program and press the "Import G-Code" button.
Search for the G-Code program you want to convert.
Then press the "Convert to DXF" button.
The program will create a file named "Data.dxf" in the same directory as the source G-code program.
If need any more help, Let me know by posting another message here.
Thanks,
Wayne
