Originally Posted by lakeside you should see if you could use a cd drive or maybe a deicated p.c. |
use of ethenet card was where I should have lead this by keep the file one one pc that not on a network or not needed for something else will speed upload time i had a protrak dpm and just kept lagre files on cd and sent code as drip feed. You just can't run anything else. Even an old pc with a disk drive thru com port 1 will do this as it only tranfering code and not running cam your dnc software must be able to handle speed
