Old 04-06-2006, 04:23 AM
locost_cam locost_cam is offline
locost_cam is on a distinguished road
Originally Posted by cwdance1
Do I have to draw the box in any certain order to get the file to run?
No, SheetCam automatically reorders your drawing.
Mach2 will cut out the box with out the nesting no problem. When I add the nesting to the post file it cuts part of the box then part of the nest then back to cutting the box.
This sounds like you have drawn parts of the box on the same layer as the slots. Go to the View menu and turn on 'Layer tool'. This should bring up a box that shows the layers in your drawing. Click on the check marks beside the layers to turn them off/on. This way you can quickly see what is actually on each layer.
I would think that you have to tell Sheetcam to do the nest first then do the outside cut, is this correct or doesn't it matter?
Each process is cut in the order that it appears in the list so if your pocket is first in the list it will cut first. You can change the order by dragging processes up and down the list using your mouse.
Have you looked at the tutorials? Go to help->Tutorials. The first two will hopefully help you understand how SheetCam works.
Les
