Hi
If you post a drawing of what you want to make, I'll write you a program that you can use as a template if it's just rings. The program will contain this, bar stop, rough turn, spot face, drill, bore, finish turn and part off, or what ever it takes to make your bit. it will be writen in fanuc G-code if thats any use and contain the offset commands. I do this most days, I program by hand at the machine. If theres any thing else just ask and we'll try to help. |
