Well here it is in beta format.
Download it from here
http://machsupport.com/forum/index.p...sg2164#msg2164
Please be gentle with me.
To get this screen set to work you will have to do a few things carefully.
Make sure you have the latest version of Mach3. (Not the Rc version)
First run the exe file, this will set up a new folder in your Mach bitmaps folder. The folder will be called "Benny Screen"
Once that is done you will need to browse to that folder and drop the "1MACHLED.ttf" font that is in there into your fonts folder. You will find your fonts folder in Start/settings/fonts/ ( right click and open) Just drag and drop the font into this folder.
Once this is done, you will find another file called "controldeskscreen.set" place this in the main Mach3 folder( C:\Mach3 )
Open Mach3 up and select Config/fonts and fro the Dros select the new font that you recently installed. ( You will find it is the very first font in the list, and you may have to scroll backwards to find it.
This font will not become effective untill Mach is restarted. (Restart Mach)
When you re open Mach 3, select View/ Load screens/ and browse for "controldeskscreen.set"
Once this is selected you should see the screen appear.
This is best viewed on a 768 x 1024 monitor. It is not suitable for smaller res monitors. I suggest if you have mach to auto scale, you turn off this setting. ( Config/state/ untick auto enlarge ( Bottom left) and restart Mach)
If your monitor is set at 768x 1024 you will need to set the windows task bar to either not display on top, or uese the auto hide feature instead. This is done by right clicking on a blankof the bar and selecting properties. You will see the options to change the settings there.
Enjoy
EDIT The sample pictures below are a bit blury since I had to decrease thier size. etc
BTW For all those who dont have Mach 3, you can download a fully working trial version that you can use forever. The main limitation is that it will only cut code for up to 1000 lines. For many this is far in excess of thier requirements anyway. If you did need to get a licence Art has made the price only $160 to look after every one. This also includes a free G-code generator as well (LazyCam). If you download one of the free Cad programs from here http://www.freebyte.com/cad/cad.htm you will never have to spend more than $160 to be completely setup for CNC software.
You can download Mach 3 from here http://www.machsupport.com/artsoft/index/index.htm
