Originally Posted by ger21 If you're running at 100%, that's probably the problem. Changing the views is probably using more CPU power than you have.
If all those programs are running in the background, you should disable them when Mach is running. Also make sure your network connection is set to a fixed speed, and not auto. |
Okay.. will set up another account on the machine with all the startups and memory-resident programs disabled, and check my network properties for fixed speed. 10Mbps will do fine since i am only running a USB1.1 wireless lan network adaptor.
Eddie
