same here o the pics. I checked into that and by default as you load the HEX code into ICPROG it selects HS as the oscillator. I believe that to be an external clock above 4Mhz . I have tried running at 4mhz with the 4mhz code and the Xtals removed but still the same. I get the motors to vibrate and turn but in a random fashion when I select ExtClk as my oscillator during pic programming. When programmed this way , if I pull the enable pin from my connector the motor stops all together and can be rotated once I reconnect the enable line the motor starts to freak out again so I believe I have enabled the motor by taking the enable line LO
I feel like it is something simple stopping them I just cant figure it out.
Thanks guys |
