  #12
Old 03-31-2006, 10:12 AM
Halfnutz Halfnutz is offline
Moderator
Halfnutz is on a distinguished road
I have a question, for anyone that may ba able to help, I have installed Mach3 and deleted Mach2 from my computer. Now if I try to run the Mach3 driver test, nothing happens. Is this a path problem, in other words,do I need to run a different driver than Mach2's? Do I need to manually install the Mach3 driver, like I had to do with the Mach2 driver? I think I probably do, just wondering if anyone else has had a similar experiance.
Update, I installed the Mach3 driver manually, but still nothing happens when I try to run the driver test from the Mach3 directory. I geusse I should try at Artsoft's support group.
Halfnutz
