  #12   Ban this user!
Old 03-29-2006, 10:04 PM
ghyman's Avatar
ghyman ghyman is offline
ghyman is on a distinguished road
Not sure what I'm looking at... all I got was several planar lines.
The .txt file is going to result in what I mentioned earlier... "If I just plunge in with a form mill (at 127 degrees), then the profile is fine, but only at the OD. As the cut approaches the center of the part, the cuts overlap each other, and the resultant ridge(s) taper down below the surface of the part."
