Old 03-28-2006, 01:11 AM
Fireflowers Fireflowers is offline
Fireflowers is on a distinguished road
Cutter comp
Cutter comp is a nice programming tool with Featurecam Mike. If the "part line program" box is checked and cutter comp is enabled in the post options box it will revert the cutter path back to the centre of the tool for the finish pass. Then it's just down to the machine opperator to add the required comp into the machine tool library to offset the finsh tool the required amount. Means small adjustments can be made quick and easy at the control without any need to alter the G code!
JJ
