Old 03-28-2006, 12:52 AM
PoppaBear10's Avatar
PoppaBear10 PoppaBear10 is offline
PoppaBear10 is on a distinguished road
Hey all,
I am putting on a OneCNC class for both Mill and Lathe, I am a Mach user, and there is a Mach mill and lathe going to be set up there. So, if you would like to take the class to see what this software CAD/Cam can do, and then Cut the part that YOU want to see done on the local machines there, sign up for the class!! (note the parts will obviously have to be within the machining capability of the lathe and mill, and available tooling. I don't work for OneCNC, I am just a satified user, I use it on my Shoptask (now 5 axis mill/2axis lathe), 3 in 1. From what I understand from Roland there will be a bench top mill, and possible a retrofitted BP mill, and a medium sized lathe. This will be my first time doing something like this, so I ask forgiveness in advanced if it is not "polished". I put in for 2 three hour classes, (I am bring a laptop projector so you can see what I am doing), the last class is at night, so we can run as late as necessary if we run over.
scott
