Old 03-27-2006, 01:11 PM
lakeside lakeside is offline
*Registered*
lakeside is on a distinguished road
check your export set-up scale I've also had files that would be sent to me that had been scaled and if you did not check the size first that could happen when dxf are scaled the entity will change but the text dimension would still be the same so a circle that the dimension said was 4" it's really 2.5" on your screen just a idea
