Old 11-04-2003, 10:10 AM
NeoMoses's Avatar
NeoMoses NeoMoses is offline
NeoMoses is on a distinguished road
When you say "graphics" what exactly do you mean? Animated gifs? Video editing/compression from digital camcorder? Photoshop work on images? Or are you going serious, like Maya?
how many computers have you built? Have you ever overclocked a computer? If not, you'll be happy to know that the system you're putting together will likely run at 3.0 GHz without a problem, maybe 3.2 GHz if you're lucky with stock cooling, and likely 3.5 GHz or faster with a good cooling solution (like the watercooler in my avatar )
My other comments: You may be better off to build a dual processor machine, especially if your 'graphics' program(s) can take advantage of it. You won't find a smoother running machine than a dually. Take a look at the MSI K7D Master-L with a couple of low-speed TBred B processors (like the 1700+) If your program is SMP capable, that system will be cheaper than the P4 system and have tons more processing power.
Also, I would always recommend buying quality, name-brand motherboards. My favorite brands are Abit and Asus, although there are plenty of other good brands.
finally, there's 2 websites I'd like to recommend.
1. www.newegg.com - hands down the best place to buy parts.
2. www.overclockers.com - be sure to check out their forums at forum.oc-forums.com . there's TONS of info there.
Hope it helps!
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
