Mike,
You must also consider the step rate-of-delivery. Are you going to control these motors with a PC and using Step and Direction software? If you are, then the bottle necked may be the PC and the step rate that the PC and software can send. Depending on the encoder count and the step rate delivered, this my be your limit for max IPM.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
