Old 03-22-2006, 07:18 AM
MarkT MarkT is offline
MarkT is on a distinguished road
Jim,
Do you have additional machining capabilities? Do you recieve any of the mechanical schematics with the machine?
If so, your most effective choice may be to make the holders and do the finish machining of them on the lathe (this is how they are made at the factory). Essentially you would mill the basic configuration for the holder and bolt holes / threaded holes on a mill (manual or CNC) external to machine. Then mount the holders on the bare turret disk that is on your machine and finish machine the bore (for turning holders) and the slot ( for turning holders) on the machine. If done correctly you can achieve great results!
Best of luck!
MarkT.
