I built a powersupply from 4 24VAC 4 amp transformers that have individual components for each transformer and then the + lines from each capacitor are ganged together for one output. The ground from the caps are also ganged together.
The output is ~35VDC and 16amps. All components are mounted in an old desktop PC case with plenty of fans. I have also mounted a 8ohm 25watt resistor from + to ground thru a switch. This drains the caps. |
