Old 03-15-2006, 07:46 PM
geoff p geoff p is offline
*Registered*
geoff p is on a distinguished road
Hi Transtar,
Yes I have a home-made cnc router; some of the electronics I scratch built and some I bought in kit form. The actual travels achieved are 500 x 400 x 50 mm. Control is by Mach2 in Demo mode - I will buy it when I have finished ironing-out the snags in my 'mechanicals'. So far my outlay has been about 20,000 baht or 300 pounds or 500 dollars US, including hardware, electronics, and motors, but not the router. Most of that went on electronics and motors.
My frame, to give it a more glorious term than it deserves, comprises two ends of 15mm plywood (about 4" x 30") separated by conduit as X-axis rails about 850mm long.
These end pieces are woodscrewed to the base (1 inch ply - 'cos it was there!) via small steel brackets. It all rests on top of a once-upon-a-time twin tub washing machine casing, which now houses my electronics and power supply.
The gantry, as some of you call it, is one round tube and one square tube spacing two substantial blocks of wood. These 'bogies' run along the X-axis on skateboard bearings, presently relying on dead-weight to keep them down.
My X- and Y-axis screws are supported in bearings outside of one rail. They are 5/8 UNC threaded rod and the nuts (sorry, followers) have a bit of iron welded-on for atachment to the carriage. I had a local machine shop turn the ends of the rod to 8mm dia to suit skateboard bearings and threaded M8 about an inch for a clamping nut. Said nut clamps the inner bearing-race, a spacer and a timing-belt pulley.
A bloody-awful mess comprises the Y-carriage carrying the Z-axis. Some more about that another time.
Motors! My Z-axis carries the full weight of both itself and the 1.5 Kg of the Bosch POF500 router. As the travelling part is a lump of 3mm plate plus guides, we are probably talking about near up to 3 Kg. A 100 oz-inch motor from IM Automation in Bangkok drives this soooo easily. The motor is rated for 2.5 A but I drive it at less for the sake of my driver electronics.
On the other hand, for X- and Y-axes I bought 200 oz-inch motors from Ocean Controls in Australia. They are hopeless! At stationary but with power applied, I cannot budge them by hand - good. But when stepping, and at their rated 600mA a light touch of finger-and-thumb simply stops them - Not Good!
Their coil current is low because their resistance and inductance are high (12 ohm and 43mH respectively) == not suited to high speed, so I cannot gear-down to gain torque at decent speed. Take a look at http://www.active-robots.com/product...r-motors.shtml where you will find (about halfway down the page) Sanyo Denki 103H7123-0151 rated at 7.35 lb-inch (~117 oz-inch) and Ohm/Phase: 6.7, Inductance/Phase: 15.0 mH, Current/Phase: 1 Amp or their next item Sanyo Denki 103H7123-0440 (also 117 oz-inch) but Ohm/Phase: 1.6, Inductance/Phase: 3.8 mH, Current/Phase: 2 Amp. Of these, the former will be better suited to low speed while the second one will maintain torque at higher speed due to its lower inductance. (I am not suggesting these 117 oz-inch motors for your purposes.)
When I save enough I will certainly replace these two with high-current, high torque motors of a reputable make (like IM, mentioned above)
Sorry to go on so much. I didn't mean to get you lost. IMHO use a 100 oz-inch motor for the Z-axis and 200 oz-inch for the X- and Y-axes. You are probably not looking for speeds in the hundreds-of-inches-per-minute range (like some commercial machines) but as I said before, the cutter needs to cut not rub the work.
For drivers, I use KT5191 (L297/L298 combos) bought from Ocean Controls and they are excellent. Having hammered the motors, I reckon I should also publically praise Peter Simmonds of Ocean Controls for his patience with me and great service. Thanks Peter.
Yonks ago I started to make some sketches of my machine but I got carried away with 'just fix this/improve that...' I will do more, and soon.
Geoff
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709
