Old 10-30-2003, 04:58 PM
camsoft camsoft is offline
camsoft is on a distinguished road
For Marc,
No, this is not normal behavior. Under the right conditions you should get a very smooth continuously un-interrupted cut at a constant velocity. However, the effects you describe are not surprising and happen to many others on all types and brands of CNC controllers when either not set up properly or the physical motors are under sized for the weight, load, gearing and inertia that the table can handle.
Honestly we have not read through all of the chats on the message board, but we do have some solid advice and explanations on this topic.
First the explanation. The better the problems are understood the better you can decide upon one of these solutions.
When stepper motors do not have enough torque (power) or are geared incorrectly for the application they are notorious for losing torque during acceleration while taking off from a dead stop, decelerating too fast to a stop, travel at the upper reaches of the RPM range for that motor or making an abrupt change in travel direction. When this happens, the motors may kick out, stall, ignore steps or freeze up.
You may be losing steps by accelerating too fast or rapiding too fast. The faster a stepper motor moves, the whimpier the stepper motors becomes thus losing torque. Although they have good torque at slow speeds. The drawback to an open loop system is that you will never know this unless you can humanly visually notice it.
The key solutions are presented in order of consideration for effectiveness, difficulty and cost.
(1) Change to closed looped servo motors.
(2) Possibly keep the stepper drives but change the stepper motors to a larger size.
(3) Use gear reducers. There are many types to select from. In-line ones that attach to the face of the motor or side mounted gear boxes are most common. Each time you reduce the gearing ratio by a factor of 2 you will increase the torque the motor has, thus doubling its power. The trade off is that each time you do this you also reduce the RPM and travel speed by half. It is common practice for companies to use , 1.5:1, 2:1, 5:1 pitches on their ball screws or install gear reducers in factors 2,5,10 or 20 to 1 for example.
(4) Use SmartPath to make automatic on-the-fly intelligent decisions about when to decel and when not to and then only apply the amount required per cutting scenario, material type, physical mechanics and up coming look ahead geometry in the cut path.
(5) Set the SLOWDOWN and NEXTMOVE parameters to automatically calculate the correct distance to commence a reduced feedrate before reaching each target position on the basis of percentage and distance of the original feedrate. This feature in part is the missing ramp up/down your speaking of. SmartPath does this same thing but with much more intelligence and versatility.
(6) Keeping in mind that steppers have the most torque at their low RPM ranges. Some solutions are in this area are:
(6a) Use lower the feedrates on G01, G02 and G03.
(6b) Open the position error allowance using POSERROR which keeps the motors from kicking out so easy.
(6c) Lower the maximum rapid speed using RAPIDSPEED to keep from running the stepper in the high RPM ranges.
(6d) Open the TOLERANCE setting up slightly. This will allow each target position reached to be satisfied more quickly and move on to the next. Don't worry about position accuracy, this system will always strive to make position and always output the exact number of steps. TOLERANCE only confirms your in-position by doing a check within the user defined tolerance range. If in-position tolerance must be confirmed on each move within a certain small value then an alternative exist by using the logic command BLEND.
(6e) Set a minus BLEND factor. This settings is in milliseconds. When the value is negative it will have a similar effect as opening tolerance, except for the unit are time based not distance based.
(6f) Insert DECELSTOP commands in your GCODE.FIL file or use G11 codes in your G code program only where necessary to automatically ramp up and down.
(6g) Lower the acceleration rate and deceleration rate using ACCEL and DECEL settings to make softer starts and stops or ramp ups and ramp downs.
Keep in mind that the focus of what your trying to accomplish is to reduce the factors that make stepper motors lose torque. The only way to approach this is to start with conservative values and make repeated tests each time slightly increasing or decreasing the values until you feel that the settings reflect adequate acceleration and deceleration for the motor size, table weight, load, gearing and inertia that your machine can handle.
For more detailed information read the Question & Answer Solutions numbers Q127, Q176 and Q195 in the CNC Professional manual. Also information for existing users can find SmartPath, SLOWDOWN, NEXTMOVE, POSERROR, RAPIDSPPED, BLEND, TOLERANCE, ACCEL and DECEL parameters in both the printed and electronic manuals.
Tech Support
CamSoft Corp.
(909) 674-8100
support@camsoftcorp.com
www.cnccontrols.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709
