No G50 or G51 blocks. This is the entire program:
G00 X0 Y0
G01 X1.5
M02
Essentially, scalling is 1 when I move each axis manually (jog -> discrete), but not when I run G-code... even as simple as that above.
It is the same for both the X and the Y axis. I haven't checked the Z.
There are no pulleys, its direct drive through some Heli-cal couplings.
Other than G50 and G51, is there any other way the scale can get set for G-code but not for jogging? |
