Old 03-10-2006, 10:24 PM
2muchstuff 2muchstuff is offline
2muchstuff is on a distinguished road
If you've had it for awhile, check the motor brushes for wear. A wore down brush will have less spring tension on it causing it to "float" on the motors commutator while running.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
