I used the Haas the other day, theres was just a couple of m codes that had to be deleted, (TurboCNC will run the program and prompt the you when it doesent understand a command) other than that it worked fine. The feed rates had to be changed too, but I edit 100% anyway so its fine for me the way it is.
__________________ Halfnutz
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
