Maybe not the only approach....
Originally Posted by ger21 Usually, the reason people have problems with the Z axis, is from trying to get a lot of travel, as well as a lot of clearance. The farther down the Z-axis is hanging, the more flex you're going to have. There's just no way around it. Raising the gantry up and down wouldnt help much, because you still have to balance travel with clearance under the gantry. |
I believe my approach (see System2) meets the requirement. In fact, because the Z axis is located
between dual Y axes, there is no difference in the amount of flex. The router mass/weight is the same if at 2 inches or 12 inches of plunge! Being centered between the 2 Y reduces the possibility of flex due to the router being mounted on just one side of the Y axis.
Just thinking sideways -
Jim
