Old 03-06-2006, 08:59 PM
bd007 bd007 is offline
bd007 is on a distinguished road
Originally Posted by Jason Marsha
What is your plunge rate between passes?
There are several reasons for each pass being off
1. Plunge rate being too fast. Although I cut at 40"/min I plunge at 6"/min even
though my Z-axis is reinforced.
2. Your Z axis runners may not be tight against the pipe all through the plunge.
3. The bit should be sharp. Pine is a strange wood with those alternating hard
and soft bands which tend to show up any flexing in the JGRO when cutting it.
I an not sure about your TCNC settings as I use Mach3.
Jason
1. I will try slowing down the plunge. I cut at about 20"/min but had the plunge set to 5 or 6 ( can't remember). I will try 3-4 tomorrow.
2. Looks tight.
3. Yes, I seen some flexing tonight. I agree pine is strange to cut. You can hear the router bogg down then speed up. I tried cutting circles with scrap MDF and still seen some flexing.
Thanks for the tips. I will try adjusting the plunge setting tomorrow.
Dave
