Old 04-15-2003, 01:21 PM
kong kong is offline
kong is on a distinguished road
Spindle size is 1", but I'm not on about using it as a lathe. Since the photo I took, i have removed the motor, leaving a nice solid housing and the spindle. I was hoping to use this as the head on a vertical mill. ie it will go up and down. just wanted to check the bearings are satisfactory on wood mills.
The copper is used to make water blocks for water-cooling computers. The one in the attatched was milled by hand in a drill press with dodgy cross-slide vice!
