Old 03-04-2006, 02:23 PM
One of Many One of Many is offline
One of Many is on a distinguished road
If you have a feedrate overide knob, it gives you the control to increase or decrease based on conditions at present. I have my CAM defaults set to 5ipm on steel, 10ipm on aluminum and use the feedrate overide 10-150%.
I have always used the calculation of:
IPM Feed rate=(chip load per flute)*(number of flutes)*(spindle RPM)
You can look up the SFM rating of the material being cut as a guide to find the RPM values based on the cutter diameter, but IMHO, use it as a guide conservatively. The strength in the cutter influences this to a greater degree than relative load assumptions in the next step to calculate a feed rate. Keep in mind that this is the MAX feed rate. Actual feed rate may be between 0 and reality to sound and feel as it is in any manual operation.
A typical standard length cutter is (more or less) designed to take a full length cut at .002-.004 per flute on 1/4 of its circumference. See attachment for detail. Cutting a path using 1/2 of the circumference is twice the load it should handle at the same feed rate or depth of cut. From my experience the depth of cut needs to be about 1/3 the diameter in that usage. Lowering the feed rate only increases the chances for chatter.
Even so, you cannot trust a 3/16" cutter to produce a 3/16" slot. Do not count on success if a no slop fit is required. Most cutters will cut oversize between wander and spinning off center.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
