Fidel,
I have emailed the manufacturer icpe to get a little more info. I believe you can use some of their motors with the R2030 however. Check the ones that use less than 100 volts and target a continuous current of around 7-8 amps or less for a good match.
I would like to see a wiring diagram of the motors but they did not provide one. I believe I had a German customer who purchased some of these motors and configured them with an encoder/commutator that he purchased in italy. I believe it worked fine.
Are there other brushless motor manufacturers in Romania as well? If not, this is probably the ones he used.
Tom Eldredge
Rutex LLC
