Old 10-21-2003, 10:20 AM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
The same general principles apply. There are several different permutations to guess through, to get the proper settings for your controller to recognise arc output properly.
As I pointed out before, you should change your maximum arc output command to 1/2 of a circle. Also, you need to discover whether the I and J components of the G02/G03 command are to be incremental or absolute position values. These settings might also change depending on whether your main program is running in absolute (G90) or incremental (G91) mode.
