This is just a guess, since I don't know your software at all, but change your maximum arc command to 1/2 or 1/4 of a full circle. This will create endpoints that are different than the start point, which is what makes a full circle arc command seem a bit "strange" to your controller, because it is already at the endpoint position named in the full circle command.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
