Try selecting all the lines in the object and then the Menu item Modify->Join Polyline, click Finish, which can be seen as a checkered flag on the menu bar at the bottom, or by right clicking. Then you can select it as an object, Right click, select Properties, Select Brush, then change it to a solid or pattern.
Hope this helps.
__________________ GlenBA
www.lathedweller.com |
