Old 10-20-2003, 07:53 AM
ToyMaker's Avatar
ToyMaker ToyMaker is offline
ToyMaker is on a distinguished road
If your spindle motor is dc, mount small capacitors (0.01 uf or so) on the motor terminals. Use 3: one from each terminal to the case of the motor, and one between the terminals. This will reduce a lot of the brush noise.
Since your limit switch is n.c. and goes low to activate an error, there must be a pull down resistor, you could connect the n.o. contacts on the switch to ground and use a pull up resistor (5-10k) on the ckt. This would solve a vibration problem.
robotic regards,
Tom
A clinician learns less & less about more & more until he knows nothing about everything. A researcher learns more & more about less & less until he knows everything about nothing.
- - anonymous
