Guys,
The electrical noise from my router/spindle on my machine causes my limit switch circuit to false trigger. I put a ferrite donut on the limit switch circuit cable with no luck. The limits are NC and the input goes low when there is a problem. All the cabling on my machine is shielded EXCEPT for the limit switch circuit. Is there a better solution of do I need to rip out the cables and replace them with shielded?
If I turn down the spindle RPM the problem goes away. (80% or below is fine).
Is there something I can put in the sindle circuit that may help?
Eric
__________________ I wish it wouldn't crash. |
