Old 10-19-2003, 12:04 PM
NeoMiller NeoMiller is offline
NeoMiller is on a distinguished road
HuFlungDung, how about if I make the plastic rod in a bit of a taper. The mold will have the cavity in plate A and the pin for center hole in plate B. The hole pin can also be made into a little lesser taper. So when I open the mold, the piece is sticking on the plate B with the center hole pin. That should be easy to remove. Wouldn't it.
