Old 10-17-2003, 09:47 AM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
To tap that thickness without a chip clean move ( or three) would be equivalent to tapping 75 mm plate with a 24 mm tap without stopping to clear the chips. You can program two or three G84's in a subroutine to provide the chip break and clearing.
You would be better off to use a seperate tap with a spiral point (for a through hole), or use a cold forming tap.
For deep threaded holes, you are usually safe to increase the tap drill diameter just a whisker, in order to make it easier to cut threads. Unfortunately, the DRAP locks you in to a process with very little flexability.
