I just made a stop for my ER spindle so that I can change tools repeatably:
Spindle Stop
As for speed changes, get a Sherline or other VS motor that uses a KB speed control and see if you can get Peter Homann's Digispeed to work...
digispeed
Yes, you usually need heat to remove the pulley, and it usually ends up being a frustrating experience...
Originally Posted by b0gh0s Well after much cursing and some bloodied knuckles I finally changed my tool holder out and put in the ER spindle/collet setup and I was able to see the difference immediately in the finish on the same parts using the same tools and same G code.
I still like the idea of going to a variable speed setup that I can program the RPMs for in code, any one have any suggestions?
BTW the bloodied knuckles were from trying to get the damn pulley off, for some reason it was really tight on that spindle and I had to use a heat gun and large wrench to pry it off. |
