Thread: Using CRC
Old 10-16-2003, 10:42 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Hi Cncrunner,
What you have described sounds like standard behaviour to me. The offset required from the exact profile is created in the controller, and not in the code.
If, on the other hand, you do not use tool nose radius comp at the machine, then you need to create a compensated (offset) path in your CADCAM. In this case, the final profile is not exactly at the part dimension, but at the part dimension + tool radius.
Note, you may have to change your tool offsets by the amount of the tool nose radius, if your controller does not have a special offset table for nose radius by itself.
