Hello,
I am hoping someone can point me in the right direction-
I have been using the lathe module for a while now. I usally do not use cutter comp for lathe work, but I thought I would try it out. The problem I ran across is that when I post the file, it outputs code as if there is a 0 radius programmed. It outputs the same code whether cutter comp is selected or not (it just adds G40,G41,G42 to the code).I tried changing the settings under file\preferences\machining from tool center to tool edge, but no luck.
Thanks in advanced,
Bill. |
