Awesome. Thanks for the great replies. Heres what I have done and the results:
Flipped the breaker below the NC, mill turned on.
Pressed the NC power button, NC turned on.
Pressed 'Home 1,' key stays lit.
Pressed '-Y,' table moved in - direction.
Pressed '+Y,' table moved slowly in + direction until zeroed. Y Home 1 and 2 lit up.
Pressed '-Z,' spindle moved in - direction.
Pressed '+Z,' spindle moved slowly + until zeroed. Z Home 1 lit up.
Pressed '-X,' spindle moved in - direction.
Pressed '+X,' spindle moved in + direction, but doesnt zero. No lights illuminate.
I can fiddle with the X axis back and forth but cant get it to zero. I can even move it to the 'X0.00' position and the light wont illuminate.
When the NC is turned on it has the codes for 'magazine zero return not completed,' and sometimes, 'maintenance check warning.' I tried clearing the codes first but that didnt help the X axis zero.
I cant thank you all enough for taking the time to reply. I'd imagine my questions might make it seem I'm beyond help, but I assure you I am going to learn this machine inside and out. Even if my head explodes.
Cheers,
Ryan |
