>>Right now when I try to shut the ATC door the NC unit show alarm 323 'ATC cover close impossible (x pos.) An attempt was made to close the atc cover although the X-axis was not the positive side of the second zero return or an X axis zero return has not been completed.'
I'm a little confused by this sentence. First, did you home the machine on startup, X-, Y-, Z-. If you didn't do this and let it return then you'll get all kinds of wierd errors. The Home button also won't work if not properly homed at startup.
If you are a little more specific about what you have done from startup until you have the error, I can probably be more help. I run an FJV20 with an Mplus at work. |
