Thread: My Machine
Old 02-16-2006, 07:34 AM
ger21's Avatar
ger21 ger21 is offline
Originally Posted by CuttersCov
Shopbot seems to over come this problem of backlash from a wide gantry design, so I may end up making my gantry supports 6" wider
The ShopBot is driven from both sides, so you can't get the skewing of the gantry you're seeing. My machine is the same way, and a lot of others are noticing it too. Bottom line seems to be that you must drive the gantry from both sides to prevent this. I'm pretty sure even a very solid and heavy steel gantry would do the same thing to some extent, unless the bearings are spaced very far apart, maybe 2 feet or so, with good linear bearings.
