Old 02-15-2006, 08:55 PM
rutexus rutexus is offline
rutexus is on a distinguished road
Tintruder,
You can choose which ever way you want to wire the transformer. When you make a 60 volt transformer with 2 thirties, you keep the current the same as they rate it. When you add two 60's in parallel you wind up doubling the current because each coil adds its current carrying capacity. It is just like adding flashlight batteries together. Two 1.5 v batteries will provide more current capacity than one AAA 1.5 volt battery. Which ever way gets you the current you need is fine. It's your choice.
They will sell direct to you. Also, tell them Tom at Rutex sent you to them.
Tom Eldredge
Rutex LLC
