Old 02-15-2006, 06:10 AM
Rance's Avatar
Rance Rance is offline
Rance is on a distinguished road
Hugo,
The printer steppers that folks usually use are from the HP II & III's. Here's some various info. I've been collecting in preparation...
Rance
Steppers scavanged from a LaserJet II or III (http://www.cnczone.com/forums/showpo...0&postcount=86)
http://www.cnczone.com/forums/showpo...0&postcount=29
http://www.cnczone.com/forums/showpo...23&postcount=6
http://www.cnczone.com/forums/showpo...2&postcount=18
LABELED: Astrosyn
TYPE: 23LM-C701-01
P/N: RH7-1048 04
5.2 V/Phase
1.4 A/Phase
1.8 Degree/Step
100 oz/in
(Drive them with 24v @ 7.5A)
[From HP LaserJet I, II, and III:
Lrg- Minibea Astrosyn 23LM-C701-01
Med- Minibea Astrosyn 23LM-S047-G1
Sml- 23LQ-C202-G2V
Wiring Diagram:
Coil A
-Green
-White/Green
-White (CT)
Coil B
-White/Red
-Red
-Black (CT)
Subject: Laserjet III to linisteppers ..... how???? (See http://www.cnczone.com/forums/showthread.php?t=16976)
From http://www.cnczone.com/forums/showthread.php?t=15797
Now you can get the HobbyCNC Board which these motors work real well with, the instruction also has the right color wire coordination for them.
I would sugest you use a min. of 24v, but I wired three computer power suplies together in series with floating ground and got 33.6volts with 8 amps (amps are limited to the lowest amperage of power suplies, so if you have two 10a power suplies and one 8 amp then your end result will be 8 amps which is pleanty for these motors rated at 1.4a each. If you need help just let me know, I wish i was into this when i was your age.
Joe
From http://www.cnczone.com/forums/showpo...9&postcount=13
Laserjet IIp and Laserjet IIIp aren't worth the effort. The motors in them are a Canon PM60-H418Z21B motor which I can't find any information on. Its a uni-polar stepper (6 wires) but the body is a non-standard size.
