I suspect that you'll end up snapping a bunch of carbide end mills by pre-drilling and then milling. Is this under some CNC control....if so then you could use a spot drill and then follow up with the appropriate drill bit.
To prevent drill bit walking (when not using a spot drill) use a split point drill bit and get the short ones designed for use in a CNC machine. |
