I don't know of anything that has to be double clicked to be selected. I just drag over a value to select it. |
double click, CTRL+A, click and drag over, shift+arrow etc etc etc. What I'm saying is, it's easier on the user. I've made several programs that do this sort of thing, and if you use it for any length of time, having the ability to just have to start typing to enter values in a new field is paramount. (In other words, making it user friendly is more important than functionality some times..
I didn't provide for tabbing between controls, because I have no way of knowing which control a user would want to go to next. |
I generally start at top left and work down or across. Grouping 'like' fields helps with this. I'm not sure about IBasic, but I know with Visual Basic, it's automatic. It starts out defaulting to creation order, but you can change the TABIndex value to customize it. I seldome use my mouse. And when I'm forced to, it's a pain. Tabbing between fields is good.
The database is in the ASCII file ME.dat. The User Guide gives detailed instructions on how to modify or add to it. |
I just ran the exe from the zip file. So I was guessing on the database.
'Rekd teh Inebriated
