Like Hu says, you look at the chart, you look at the machine and setup, you think about the things you have turned in the last 20 years (and how that has all worked out) then you pick numbers while holding your tongue in the correct position.
Once you start cutting you make constant adjustments untill you are satisfied.
Clear as mud eh
