Thread: laser 1200-60W
  #12   Ban this user!
Old 02-05-2006, 01:36 AM
hkxy hkxy is offline
hkxy is on a distinguished road
CO2 Laser Technical Parameter
Length (mm):1200(250,400,450,500,600,700,800,1000,1400,1600,1800)
Mode(mm):Lower mode
Outer diameter(mm):Φ54±2(30,36,50,54,60,65)
Ignition voltage(KV):24(7,11,12,13,18,19,20,22,24,26,28,30)
Operating voltage(KV):16(6,9,10,11,12,13,15,16,17,18,20)
Operating current(mA):24(5,12,14,15,16,18,20,22,24,26,28,30)
Power Output(W):60(4,12,16,18,24,30,35,40,60,75,90W)
Power stablility:≤±5
Quality factor M2 1.2±0.2
Laser pattern TEM00 or TEM01
Light beam diameter lens
Design life 10,000 hours
He needs a power source:I purchase the price is $610USD
Possible choice:$260+$610=$870USD.
I have purchased,Produces the merchant to tell me it the life is 10,000 hours,6 months,Is not SY $7000,The cost is lowConforms to my requirement
He and SY is the different typeHas the difference the model
Thank you about balsa pieces and the less char suggestion
1st, input voltage: AC 220V±15%,
AC110V±15% (when ordering should explain specially);
2nd, maximum output voltage: DC 28KV (1250mm);
3rd, maximum output electric current: DC 20mA (1250mm);
4th, speed of response: <= 1mS.
5th, TTL level switch control: DC 5V;
6th, protects the switch: (1) lacks the water protection, (2) has flowed the limit protection, (3) overvoltage protection;
7th, the laser output adjustment (uses advanced PWM control technology):
(1) the 0-5V simulated signal, the control laser energy adjustment (coordinates software);
(2) TTL level switch control frequency output: DC 5V;
(3) by potentiometer manual regulation laser power source output current.
8th, use environment: Temperature (-10 ~ 40) ℃, humidity: <= 85%.
9th, external dimensions: 265×225×80 (long * width * is high) mm.
