I have tried it. It does work pretty good. The way that I did it was I created trim planes at all the Z levels I wanted to cut. Then I created surface intersect splines where the trim plane and the part met. I used those splines as boundries for the truemill path. Then I use trumill reference to clean up the corners.
This is a pain in the neck. I hope they put this in soon! |
