I'm still learning Mach as well, but I think you missed what Gerry said:
"If you're importing a .dxf, set the speed in the import dialog box, use the layer button.
Gerry"
There you can set the feed rates for plunge and direction, I think they default to 1 untill you change them, then they stay at what you set for the futer.
The motor tunning should not matter to generate the G-code, it will generate what ever you tell it to, if your machine can't run that fast, well..... |
