Originally Posted by thunterman
I have wired home and limit switches on all three axes. At the present I am having some noise/crosstalk issues on the long limit switch wires. I will need to wire the shields on wires to ground to resolve this issue. I hope that will correct the problem. |
If your using Mach3, try increasing the "Input Debounce" in the Logic settings screen, to maybe 2000, or even 5000 and see if that helps.
