I have been working on proman for some time. I started in version 18. I hve had a issue with it for some time. I do parts with alot of intersecting holes "over 100+". Pro will see the intersecting hole then only connect enough for full diameter. This works well 90% of the time. Some of my holes have threads going almost to the bottom of a hole or need more than simply a connection for a parts that fits in the hole. Other than doing a instance of my part I see no other way to control the depth when there is an intersecting hole. I tried all the parameters with no luck. I want to use the geometry of the hole to control depth so when there is an engineering change my hole depth will change as well. Any ideas?
TIA
Cncwhiz |
