Originally Posted by DareBee Right, that slipped my mind, a lot of plants I am in use soft copper tubing which is the same as the brake line thing. |
Yikes! I hope nobody takes this and applies it backwards and uses soft copper tube as a brakeline.
I have used soft copper but it turns into hard copper with bending and then just as you are tweaking it that last little bit it cracks. I will admit it does less damage to a carbide tool spinning at 10k than steel tubing though.
